[GRASS5] configure.in Wants testers...gl for cygwin
John Huddleston
jhudd at lamar.colostate.edu
Fri Dec 29 09:35:49 EST 2000
Eric, (Grass)
Using the line
gcc -o gltest gltest.c -lGLU -lGL -L/usr/X11R6.4/lib -lX11 -lSM -lICE -lXext
will compile the test source code that you have in the
configure script under Cygwin to use the GL libes.
John Huddleston
----- Original Message -----
To: "GRASS5-dev" <grass5 at geog.uni-hannover.de>
Sent: Thursday, November 23, 2000 10:32 PM
Subject: [GRASS5] configure.in Wants testers...
> Okay,
> I think I've implemented all of the checks in the hacked configure
> script in configure.in. So, now I need others to test it and give me
> problem reports. I haven't added anything, like searching for libjpeg,
> yet. I want to get the input script at least to where the hacked
> configure script is before I start adding things. Probably there will
> be search paths for things that I didn't think of. Anyway, make a
> backup of the configure script and delete your config.cache before
> running autoconf. Also, note that there doesn't seem to be a good way
> to have the --bindir default to /usr/local/bin. The macro
> AC_DEFAULT_BINDIR() was not recognized by my autoconf and the variable
> $bindir is always set to something (defaulting to ${exec_prefix}/bin,
> where $exec_prefix defaults to ${prefix} which is set to
> /usr/local/grass5 by default. Confused?). So, if you want
> /usr/local/bin for $bindir, you need to specify it. Also, see
> ./configure --help for some of the options (they need testing too).
> Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
