[GRASS5] configure.in Wants testers...tk check
Eric G . Miller
egm2 at jps.net
Fri Dec 29 13:16:06 EST 2000
On Fri, Dec 29, 2000 at 07:09:09AM -0700, John Huddleston wrote:
> Eric, (Grass)
> I was looking at the configure.in script and was going to make
> the analogous changes to it to resolve the tk check problem
> and noticed that the naming convention for variables is
> not consistent for the X11 logic. It expects a X_LIBS
> variable to be set. Following the original syntax, it would
> be X_LIBRARY_DIRS.
Yes it expects X_LIBS because that is what is set earlier in the
configure script. Also, there was no tk check problem. If you look more
carefully, the -ltcl$tcltk_ver is added to $LD_FLAGS, but the check is
performed on tk$tcltk_ver. What's needed for cygwin is the addition of
a tcltk_ver="80".
> Let me know if you want me to edit the configure.in for the
> tk check fix or if you will do it.
No, cause what you describe is not a problem.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
