[GRASS5] Re: [GRASSLIST:1299] Re: Grass 5b10 make clean
Eric G . Miller egm2 at jps.net
Thu Dec 21 11:32:39 EST 2000
On Thu, Dec 21, 2000 at 06:40:29PM +0700, Justin Hickey wrote:
> So you have a choice for the source and install directories, but the
> build directory is dependent on how the Makefile is written. All I'm
> doing is rewriting the Makefile so the build directory is in the usual
> place.
> Are we understanding each other now? I was confused as to what you were
> trying to point out. Sorry.
Yes, the problem is the modules should be fully built in OBJ.$(ARCH)
with "make" or "make all".  But the modules/libes/etc, should not be
"installed" unless "make install" is run.  So, I think we are
understanding each other...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
