[GRASS5] Re: [GRASSLIST:1315] Re: r.support
Markus Neteler
neteler at geog.uni-hannover.de
Wed Dec 20 12:59:57 EST 2000
On Wed, Dec 20, 2000 at 05:52:38PM +0100, mlennert at club.worldonline.be wrote:
> > On Wed, Dec 20, 2000 at 04:21:50PM +0100, mlennert at club.worldonline.be wrote:
> > > What's the news on r.support ? In the current CVS version it does not seem to
> > > be included, and on the web page it is marked as needing updating.
> > > In the meantime, do I have to edit the category file by hand ?
> > Hi Moritz,
> > you have to CVS update r.support like that:
> > cvs up -dP src/raster/r.support
> > Then it will appear again in your copy (I have splitted the code into
> > cmd/ and inter/ subdirectories).
> > Cheers
> > Markus
> Thanks, now it works. I just had the following problem compiling:
> I first tried to compile from the src/display/r.support directory. I got the
> following error message:
> /usr/local/src/cvs/grass/src/raster/r.support/cmd
> make -f OBJ.i686-pc-linux-gnu/make.rules
> make[1]: Entering directory `/usr/local/src/cvs/grass/src/raster/r.support/cmd'
> make[1]: *** No rule to make target `/usr/local/grass5/etc/modhist', needed by
> `all'. Stop.
> make[1]: Leaving directory `/usr/local/src/cvs/grass/src/raster/r.support/cmd'
> make: *** [all] Error 1
You are right.
Fixed. Please
cvs update src/raster/r.support/cmd/Gmakefile
Funny, my gcc doesn't complain...
Now it should compile.
Sorry for this inconvenience,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
