[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Markus Neteler
neteler at geog.uni-hannover.de
Wed Dec 20 05:03:31 EST 2000
On Tue, Dec 19, 2000 at 01:00:57PM +0100, mlennert at club.worldonline.be wrote:
> On Debian, XFree3.x read XF86Config and XFree4.x reads XF86Config-4, so I'm
> not sure this is a distribution problem. Isn't just a question of what version
> of XFree you use ?
Hi Moritz,
the Suse7 with Xfree4.0.1 reads /etc/X11/XF86Config,
the Suse6 with Xfree3.6.6 reads /etc/XF86Config
So it *is* dependent on the distro (welcome to the standardized
world of UNIX).
Markus
PS: I'll add a note onto the FAQ.
> > On Tue, Dec 19, 2000 at 04:38:43PM +0700, Justin Hickey wrote:
> > > Hi Markus
> > > Markus Neteler wrote:
> > > > > bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
> > > > which Xfree are you using? Which windows Manager?
> > > > Myself, the problem also persists on Xfree 4.0.1 and KDE 1/2.
> > > > Xfree 4.0.1 with fvwm2 is fine.
> > > > Time to investigate!
> > > If you hadn't noticed, the person who reported this bug is one of my
> > > colleagues.
> > Hi Justin,
> > yes, I have seen that.
> > > We found that the problem was that Red Hat does not use the
> > > XF86Config file but one named XF86Config-4 instead. Once we put the
> > > backingstore fix in the other file, the problem was fixed. Perhaps your
> > > system is similar?
> > Aha! Please describe the Redhat version, that I can add such a note
> > on the FAQ page.
> > However, I have:
> > xdpyinfo |grep -i back
> > options: backing-store YES, save-unders YES
> > Do it is activated. But still this is causing problems on KDE2 (KDE1 as
> > well).
> > SuSe reads the /etc/X11/XF86Config.
> > Yours
> > Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
