[GRASS5] Re: Release beta11
Eric G . Miller egm2 at jps.net
Tue Dec 19 21:56:34 EST 2000
On Tue, Dec 19, 2000 at 09:39:17AM +0000, Markus Neteler wrote:
> [cc to grass5]
> On Tue, Dec 19, 2000 at 11:22:15AM +0700, Justin Hickey wrote:
> > Hi Markus
> > I was just thinking about releasing beta 11 and I was wondering if we
> > need to temporarily back anything off the CVS tree. Should we check
> > through the log and see what was added to determine if anything should
> > be backed out? In particular, I was thinking of the new compression
> > algorithm code. Just a thought.
> Hi Justin,
> maybe yes. The compression algorithm is the only major thing currently
> in CVS. If releasing beta11 these days, we should bother the users
> with this as well. Better we "calm down the waves" not to loose all
> our friends.
> Eric, would that be o.k. with you?
Fine with me.  Just need to uncomment the USE_LZW_COMPRESSION define at
the top of libes/g3d/fpcompress.c, libes/gis/put_row.c and
libes/gis/get_row.c.  If you want to do that, then tag the version and
then revert it, that'd be great.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
