[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Dec 19 04:38:43 EST 2000
Hi Markus
Markus Neteler wrote:
> > bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
> which Xfree are you using? Which windows Manager?
> Myself, the problem also persists on Xfree 4.0.1 and KDE 1/2.
> Xfree 4.0.1 with fvwm2 is fine.
> Time to investigate!
If you hadn't noticed, the person who reported this bug is one of my
colleagues. We found that the problem was that Red Hat does not use the
XF86Config file but one named XF86Config-4 instead. Once we put the
backingstore fix in the other file, the problem was fixed. Perhaps your
system is similar?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
