[GRASS5] bugreport r.drain (?)
Markus Neteler
neteler at geog.uni-hannover.de
Mon Dec 18 11:34:34 EST 2000
Hi again,
while looking again at r.drain source code it seems that
my drain problems are a feature, not a bug.
This algorithm drains into *all* neighbors where the elevation
is lower than the central cell, but without weightage. So
it seems to be an algorithm between D8 and FD8. I'll add
a note on this behaviour onto the html page.
Sorry for this confusion,
Markus
PS: I am still searching for a method to drain a simple raindrop
through an elevation model following the "valleys", but following one
path only (D8). I need it for educational purposes only. Any ideas?
I tried r.cost (which *is* working) without full success for my purposes.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
