[GRASS5] [GRASS-bugs] Bugreport GRASS 5
Wwises at hpcc.nectec.or.th
Mon Dec 18 04:37:00 EST 2000
Below is the result of your feedback form. It was submitted by
(Wwises at hpcc.nectec.or.th) on Monday, December 18, 2000 at 09:36:58
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: RedHat
cputype: Intel (i486, i586, pentium ...)
grassversion: Linux/Intel binaries
cvsyesno: -- select --
source_version: 5beta10
module: X window repaint
bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
Identifier "Generic VGA"
VendorName "Unknown"
BoardName "Unknown"
Chipset "generic"
Option "backingstore" "on"
# VideoRam 256
# Clocks 25.2 28.3
EndSection
# Device configured by Xconfigurator:
Section "Device"
Identifier "nVidia Corporation|Vanta [NV6]"
BoardName "Unknown"
#VideoRam 16384
# Insert Clocks lines here if appropriate
EndSection
As you can see, the backingstore feature has been set but the problem still persists. Any clues as to what to do?
compiler: -- select --
name: Wisa Wisesjindawat
REMOTE_HOST: cache1.nectec.or.th
If you want to unsubscribe from grass-bugs
mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass-bugs'
If you want to unsubscribe from GRASS Development Team mailing list write to:
subject 'unsubscribe grass5'
