Subject: Re: [GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Dec 18 03:55:38 EST 2000
Ooops! I forgot to attach run.c. Here it is.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
this program runs its arguments as a commmand. it essentially
does what the sh would do to look for the command. if / occurs in
the command it runs it as is, otherwise it search the PATH
variable. care is taken to preserve the PATH variable that is
passed (as part of the environment) to the command being invoked.
the signals SIGINT and SIGQUIT are set to the default action
before running the command.
This program is needed because the GIS shell must ignore
interrupts when it runs the user's shell. There is no way to tell
the user's shell to re-activate interrupts in shell-ese.
#include <stdio.h>
#include <stdlib.h>
#include <signal.h>
#include <unistd.h>
#include "local_proto.h"
int main (int argc, char *argv[])
char *PATH;
char path[1024];
char *a,*b,*c;
int more;
signal (SIGINT, SIG_DFL);
signal (SIGQUIT, SIG_DFL);
argc--;
argv++;
if (argc <= 0) exit(1);
execvp (argv[0],argv);
fprintf (stderr, "%s: Command not found\n",argv[0]);
exit(127);
exit(0);
