[GRASS5] Re: CVS update: grass/src/general/g.version
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Dec 15 08:44:45 EST 2000
Hi Justin,
sorry for the confusion. After i posted the message to the list (which
said that i work on a fix) i had no time to update my changes.
Yesterday i got my linux system up'n'running again after a major upgrade
and checked in the changes.
I have the problem that with the last working setup i get a g.version
output on IRIX (with gcc) that has double line spacing. This IMHO is
something different from the missing newline in the sed.script. I think
that gcc is broken in a way that interprets the \n and the embedded
newline both.
I'll revert the changes and try to find the problem.
cu,
Andreas
Justin Hickey wrote:
> Hi Andreas
> grass at intevation.de wrote:
> > Date:   Thursday December 14, 2000 @ 23:36
> > Author: andreas
> > Update of /grassrepository/grass/src/general/g.version
> > In directory intevation.de:/tmp/cvs-serv28343
> > Modified Files:
> >         Gmakefile sed.script
> > Log Message:
> > fixed double line spacing on IRIX (hope so)
> > If you want to unsubscribe from GRASS Development
> > Team internal mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass-commit'
> I just updated your changes posted here and g.version only prints the
> grass version. The copyright message is not printed at all on an SGI
> Origin 2000 running IRIX 6.5.
> Yesterday, I was having a problem with newlines, and it was fixed by
> putting a blank line at the end of the sed.script file. I have no idea
> how a new line character at the end of the sed command can effect the
> output of the copyright, but it did. After the fix, the copyright was
> working fine on my IRIX. I don't know why you would get double line
> spacing on your machine. Strange.
> Just thought I would let you know.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
