[GRASS5] GRASS5 CVS on Red Hat 7.0
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Dec 14 18:56:27 EST 2000
Hi all,
some good news: I just recompiled the CVS version on a brand new RH 7.0
installation without any major problems.
One weird thing is that i have no static tcl/tk libraries around, only
some stub lib. So configure does not recognize, but nviz compiles and
works. Tcltkgrass too. See attached text.
The mesa setup worked without any manual installation/recompiling. There
is even a rpm for the SGI Widgets, that have been missing/not compiled
by default with mesa.
But r3.showdspf does not work. It displays only some coloured stripes. I
have no time to investigate this, but it could be a problem that i have
installed Mesa, some IRIS GL compatibility lib, OpenMotif, LessTiff, the
SGI Widgets and some other OpenGL stuff, which could interfere.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
no libtk*.a nor libtcl*.a on my RH 7.0 Linux system,
see:
locate libtcl
/usr/lib/libtcl.so
/usr/lib/libtcl8.3.so
/usr/lib/libtclstub8.3.a
/usr/lib/libtclx.so
/usr/lib/libtclx8.2.a
/usr/lib/libtclx8.2.so
locate libtk
/opt/office52/program/libtk569li.so
/opt/office52/program/libtkt569li.so
/usr/lib/libtkx.so
/usr/lib/libtkx8.2.a
/usr/lib/libtkx8.2.so
/usr/lib/libtk.so
/usr/lib/libtk8.3.so
/usr/lib/libtkstub8.3.a
ncurses.h error
