[GRASS5] Compiling beta10 on LINUX (RedHat 7.0)
David Delorme ddelorme at gatewest.net
Tue Dec 12 10:37:15 EST 2000
Markus Neteler wrote:
> On Sat, Dec 09, 2000 at 07:26:38PM +0100, Federico Ponchio wrote:
> > Hi,
> >       i had the following error message when compiling
> > the beta 10:
> > [root at snarf vask]# gmake5
> >   SRC = /usr/local/src/grass5.0beta10/src
> >   CMD = /usr/local/src/grass5.0beta10/src/CMD
> >   HEADER = head.i686-pc-linux-gnu
> >   ARCH = i686-pc-linux-gnu
> >   GISBASE = /usr/local/grass5
> >   VERSION = 5.0beta10 December 2000
> > /usr/local/src/grass5.0beta10/src/libes/vask
> >   make -f OBJ.i686-pc-linux-gnu/make.rules gcc -g -O2 -DMAKE_VASK_LIB
> > -I/usr/include/ncurses.h -I/usr/local/src/grass5.0be ta10/src/include -c
> > V_call.c -o OBJ.i686-pc-linux-gnu/V_call.o
> > /usr/include/ncurses.h: Not a directory
> > which comes from the line:
> > EXTRA_CFLAGS  = -DMAKE_VASK_LIB -I/usr/include/ncurses.h
> > in src/libes/vask/Gmakefile
> > I removed the "/ncurses.h" part and all works correctly now.
> Hi Federico,
> thanks for this! I have removed the hard-coded entry in CVS.
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
In my system i have a dir called ncruses as well as having ncurses.h in
the parent dir.
I have noticed that the up, down, left, right, del, backspace or space.
which is a hassle when you have to set up a new location and especially
a default region. thanks for the other info i got grass to compile fine
with the exception of png stuff and clump...
Type: text/x-vcard
Desc: Card for David Delorme
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001212/184bda08/ddelorme.vcf
