[GRASS5] make on linux RedHat 7.0
David Delorme
ddelorme at gatewest.net
Sun Dec 10 13:46:56 EST 2000
loading cache ./config.cache
checking host system type... i586-pc-linux-gnu
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking whether ld -s works... yes
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for ranlib... (cached) ranlib
checking for env... (cached) env
checking for f77... (cached) f77
checking how to run the C preprocessor... (cached) gcc -E
checking for X... (cached) libraries /usr/X11R6/lib, headers
/usr/X11R6/include
checking for dnet_ntoa in -ldnet... (cached) no
checking for dnet_ntoa in -ldnet_stub... (cached) no
checking for gethostbyname... (cached) yes
checking for connect... (cached) yes
checking for remove... (cached) yes
checking for shmat... (cached) yes
checking for IceConnectionNumber in -lICE... (cached) yes
checking for ANSI C header files... (cached) yes
checking for curses.h... (cached) yes
checking for limits.h... (cached) yes
checking for termio.h... (cached) yes
checking for termios.h... (cached) yes
checking for unistd.h... (cached) yes
checking for values.h... (cached) yes
checking for zlib.h... (cached) yes
checking for sys/ioctl.h... (cached) yes
checking for sys/mtio.h... (cached) yes
checking for sys/resource.h... (cached) yes
checking for sys/time.h... (cached) yes
checking for sys/timeb.h... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/utsname.h... (cached) yes
checking whether time.h and sys/time.h may both be included... (cached)
yes
checking for off_t... (cached) yes
checking for uid_t in sys/types.h... (cached) yes
checking curses.h WINDOW structure component... _maxy
checking for ftime... (cached) yes
checking for gethostname... (cached) yes
checking for gettimeofday... (cached) yes
checking for lseek... (cached) yes
checking for nice... (cached) yes
checking for time... (cached) yes
checking for uname... (cached) yes
checking for seteuid... (cached) yes
checking for setpriority... (cached) yes
checking for setreuid... (cached) yes
checking for setruid... (cached) no
checking whether setpgrp takes no argument... (cached) yes
checking for initscr in -lncurses... (cached) yes
checking for gtty in -lcompat... (cached) no
checking for tgetent in -ltermlib... (cached) no
checking for xdrmem_create in -lsun... (cached) no
checking for xdrmem_create in -lnsl... (cached) yes
checking for xdrmem_create in -lc... (cached) yes
checking for deflate in -lz... (cached) yes
checking for atan in -lc... (cached) no
checking for atan in -lm... (cached) yes
checking for dlsym in -ldl... (cached) yes
checking TIFF include dirs... -I/usr/include
checking TIFF library dirs... -L/usr/lib
checking for TIFFOpen in -ltiff... (cached) yes
checking Tcl include dirs... -I/usr/include
checking Tk include dirs... -I/usr/include
#### output from ./configure #######
checking Tcl/Tk library dirs...
checking for Tk_MainWindow in -ltk8.3... (cached) yes
checking libpq-fe.h... -I/usr/include/pgsql
checking libpq paths... -L/usr/lib -L/usr/lib/pgsql
checking for PQcmdTuples in -lpq... (cached) yes
checking GL/gl.h and GL/GLwMDrawA.h... -I/usr/include/GL and
checking for glBegin in -lGL... (cached) yes
checking for gluBeginCurve in -lGLU... (cached) yes
checking for GLwDrawingAreaMakeCurrent in -lGLw... (cached) no
checking for GLwCreateMDrawingArea in -lGLwM... (cached) no
checking for sql.h... (cached) no
checking for jpeglib.h... (cached) yes
checking for jpeg_start_compress in -ljpeg... (cached) yes
creating ./config.status
creating Makefile
creating src/CMD/head/head
creating src/scripts/shells/create_fifos.sh
creating src/include/config.h
src/include/config.h is unchanged
#### output from make install #####
test -d /usr/local || mkdir -p -m 755 /usr/local
test -d src/CMD/next_step || mkdir -p src/CMD/next_step
test ! -f src/CMD/head/head || mv src/CMD/head/head
src/CMD/head/head.i586-pc-linux-gnu
UNIX_BIN=/usr/local/bin SRC=/usr/src/grass MAKE=make NAME_VER=5
GISBASE=/usr/local/grass5 MACHINENAME=`uname -n` /bin/sh
src/CMD/generic/CREATE_GMAKE.sh i586-pc-linux-gnu /usr/local/bin
/bin/sh /usr/src/grass/src/CMD/generic/is64bit.sh i586-pc-linux-gnu
Now proceed with make install
GRASSSRC=/usr/src/grass/src GMAKE=/usr/src/grass/src/CMD/gmake5.0
HEADER=head.i586-pc-linux-gnu MAKE=make /bin/sh
src/CMD/generic/GISGEN.sh
CMD=/usr/src/grass/src/CMD
ARCH=i586-pc-linux-gnu
GISGEN Sun Dec 10 12:38:35 CST 2000
GISBASE = /usr/local/grass5
SRC = /usr/src/grass/src
CMD = /usr/src/grass/src/CMD
HEADER = head.i586-pc-linux-gnu
ARCH = i586-pc-linux-gnu
GISGEN failure: /usr/local/grass5 - directory doesn't exist
Why does it not want to create the grass5 dir.
I created the dir but got error say can't create lock file or something
like that when i try to run grass 5
Type: text/x-vcard
Desc: Card for David Delorme
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001210/f4d599c4/ddelorme.vcf
