[GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
Eric G . Miller
egm2 at jps.net
Sun Dec 10 13:13:35 EST 2000
On Sun, Dec 10, 2000 at 05:12:37PM +0000, Markus Neteler wrote:
> On Sun, Dec 10, 2000 at 06:30:46AM -0700, John Huddleston wrote:
> > No Markus, you do not have to change 60% of the Gmakefiles.
> > if beta10 comes from the cvs.
> > I modified all the files to be $(LIBS) $(XDRLIB) $(MATHLIB)
> > when I first started. It is usually new files that potentially may
> > have incorrect order. The rules depends on which LIBS are
> > included. Some require XDRLIB and some don't.
> O.k.... Do you have any hints *when* XDRLIB is required? How
> to find out (another way as bothering Andreas or you :-)
> when to added this to CC line? I'll put a note into SUBMITTING
> then (we already have a nice Gmakefile section there!).
Any module that does raster manipulations (from gislib) needs the
XDRLIB.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
