[GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
John Huddleston jhudd at lamar.colostate.edu
Sun Dec 10 08:30:46 EST 2000
No Markus,  you do not have to change 60% of the Gmakefiles.
if beta10 comes from the cvs.
I modified all the files to be $(LIBS) $(XDRLIB) $(MATHLIB)
when I first started.   It is usually new files that potentially may
have incorrect order.  The rules depends on which LIBS are
included.  Some require XDRLIB and some don't.
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Saturday, December 09, 2000 11:06 AM
Subject: Re: [GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
> On Sat, Dec 09, 2000 at 01:07:58PM +0100, Andreas Lange wrote:
> > Hi 2 all,
> > i want to report some problems i found with GRASS5.0beta10 (not the CVS
> > version!) on IRIX 6.5 and CYGWIN.
> > I am tired of fixing the same problems again and again. So i want to ask
> > everyone to remember:
> > The Gmakefile lib order _must_ always be:
> > Otherwise on IRIX it won't compile. If you are linking to the gis lib,
> > you must always include $(MATHLIB), as gis references floor, ceil, etc.
> > from the math lib. If you are not sure, add $(XDRLIB) $(MAHTLIB), it
> > won't hurt.
> Hi Andreas,
> actually I don't see the problem:
> Is the order:
>  $(LIBS) $(MATHLIB) $(XDRLIB)
> causing problems? If yes, we have to change 60% (or more) of the Gmakefiles.
> If so, please modify SUBMITTING. I have a script here which could do
> the change of order.
> Generally I was sure that 99% of the Gmakefiles are ok. Obviously I am
> wrong?
> How does Justin manage if not (he is using Irix, too)?
> As Linux doesn't complain if $(XDRLIB) is missing, what is the rule for this
> requirement? Then I can check all Gmakefiles...
> Little confused (as beta10 is rather identical to CVS at time),
>  Markus
> PS: I'll look into problems mentioned below:
> > I had to heavily edit the header file for CYGWIN, there are still a lot
> > of problems with include and lib search paths etc.
> > And the command line/text mode interface is not working any more.
> > Please see the attached file for the problems in detail.
> > I have currently no time to work on the fixes myself. I will concentrate
> > on the XDRIVER/fifo/ipc stuff.
> > Andreas
> > Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> > Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
> > GRASS5.0beta10:
> > IRIX:
> > g.version has double \n's (fix is on the way)
> > gis_set.tcl: -state disabled instead of -state disable
> > gis_set.tcl: string compare -nocase: not supported
> > although this is supported from tk8.2 on, it is not
> > ok to use this if we claim tk8.0 compatibility.
> > when converting the man pages:
> > many error messages with awf formatter:
> > . DE not available (or such)
> > g.manual from tcltkgrass:
> > Illegal option -- P
> > Usage: man ...
> > g.manual entries=d.area -f:
> > Usage:
> >  g.manual .....
> > this is all messed up, rman: please do not ask the user to install
> > something from within Usage info. This will confuse "ordinary" users.
> > CELL driver seems to work on IRIX in latlon. (colors sometimes incorrect)
> > in spearfish/UTM the intermittend white lines still appear.
> > r.mapcalc:
> > couldn't reproduce the behaviour Anantha Prasad reported.
> > This BUG is gone.
> > The problem with the reduce/reduce conflicts on compiling
> > can IMHO be ignored, as the output of the parser is parsed again
> > with a C program. To my knowledge the parser is ok and
> > i know of no errors.
> > This is the same with r3.mapcalc.
> > r.in.png does not work
> > (r.out.png, then r.in.png with this image gives me a totally white
> > raster on IRIX). r.stats says: 100% * (NULL)
> > r.in.tiff on IRIX:
> > r.in.tiff [1591] - out of logical swap space during exec - see swap(1M)
> > killed.
> > argh, i have 128 MB RAM and another 128 M RAM swap.
> > Must be some sort of segfault. This happens when invoking only
> > r.in.tiff, without any arguments!
> > wrong order of libs: $(MATHLIB) in
> > src.garden/answers/src.answers/display/d.lingraph/cmd/Gmakefile
> > src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Gmakefile
> > CYGWIN:
> > grass5
> > /usr/local/grass5/etc/Init.sh: not found
> > does not start with and without any commandline flag (-text, -tcltk etc.)
> > COMPLETELY BROKEN NOW!
> > GENERAL:
> > g.help:
> > PAGEUP/PAGEDOWN: doesn't work on every terminal.
> > E. g. on IRIX it is broken.
> > This needs to take the termcap into account. It is not possible
> > to hardcode the keycodes into the program.
> > t.roads.inf from spearfish database is broken/wrong format.
> > no cat support (informix db?)
> > tests that i performed:
> > for f in `g.mlist type=rast` ; do
> >   d.erase white
> >   echo "plotting $f"
> >   d.rast $f
> >   sleep 2
> > done
> > and with d.vect, d.area, d.site etc.
> > andreas lange, 12/2000
> Dipl.-Geogr. Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
