[GRASS5] configure.in Wants testers...
Markus Neteler neteler at geog.uni-hannover.de
Tue Dec 5 12:51:08 EST 2000
On Tue, Dec 05, 2000 at 05:40:51PM +0000, Markus Neteler wrote:
> Hi Eric,
> a report on configure... If *not* runnung autoconf, the
> GISBASE             = @GISBASE@
> is not expanded in head file (tested on Solaris without autoconf).
> If running autoconf, it is o.k. (tested on Linux). It seems,
> some code needs to be added to configure. Will you look for
> that? I have added the "sed" line for GISBASE already to
> get an empty variable in head file.
Hi again,
I have added the missing code now in "configure" (taken from an
autoconf/configure run). Please check if o.k.
Thanks
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
