Fwd: Re: [GRASS5] New MacOS X compilation errors
Jeshua Lacock
jeshua at SierraMaps.com
Mon Dec 4 16:06:38 EST 2000
>Hi Jeshua,
>there are still some odd things with the header. If this header was
>generated with the latest configure, Eric should have a look at it for
>what i marked.
Thanks Andreas! Yes it was configured with the latest configure.
>If you need a quick fix, please try to edit the file manually.
I will poke around the file and see if I can't figure something out.
The thing I do not understand is when to use the switches like -l or
-L as in = "-L/usr/X11R6/lib". In other words If I try adding a
path, I do not know if I need to add some switch in front of it.
>I would recommend to do a "make distclean" (this will remove the
>complete Installation and the object and library files) and to re-run
>./configure. If the header file does not change, please mail again.
Well I would, but I just did that. Note that the entire tree was
updated prior to cleaning and configuration.
>Jeshua Lacock wrote:
>> Thanks Andreas and Eric!
>> After deleting and updating connect.c, it compiles just fine. I
>>still get the error:
>> __XErrorFunction
>> __XIOErrorFunction
>> __Xdebug
>> Here's by header file:
>> CC = cc
>why not gcc? Which compiler do you have installed? Is there a Mac OS X
>specific compiler installed?
>> FC =
>no Fortran compiler, some modules will not compile.
>If you have installed gcc, you should add g77 here.
I cannot get gcc/g77/f77 installed. The Apple Developers Kit comes
with cc only. I have heard a rumor that I should try the gcc CVS
snapshot. I think I will.
> > LEX = flex
>> YACC = yacc
>> ARCH = powerpc-apple-darwin1.2
>> MAKE = make
>> prefix = /usr/local/grass5
>> exec_prefix = /usr/local
>> GISBASE = /usr/local/grass5
>> UNIX_BIN = ${exec_prefix}/bin
>> DEFAULT_DATABASE =
>> DEFAULT_LOCATION =
>> COMPILE_FLAGS = -g -O2
>> LDFLAGS =
>No stripping. This is the reason your binary distr. so much bigger than
>on e. g. Linux.
>Try putting "-s" here and check if it compiles. Your bindist will shrink
>to about 40 MB with this.
I will try with the next dist.
>> DLLIB =
>> XCFLAGS = -I/usr/X11R6/include
>Try -I/usr/X11/include here if you have this directory. This could be
>the reason for the above cited error.
>Just a wild guess.
No such directory as /usr/X11 for me, it is in fact located at /usr/X11R6.
> > # XXX - replace SYSV in code with configure results in config.h
>> # XXX - need SYSV defined for hpux10
>> XLDFLAGS =
>> XINCPATH =
>> XMINCPATH =
> > XLIBPATH = -L/usr/X11R6/lib
>> XTLIBPATH =
>> XMLIBPATH =
>> XLIB = -lSM -lICE -lX11
>> XTLIB = -lXt
>> XMLIB = -lXm
>> XEXTRALIBS =
>> COMPATLIB =
>> TERMLIB =
>> CURSES = $(TERMLIB) $(COMPATLIB)
>> MATHLIB =
>> XDRLIB =
>> ZLIB = -lz
>> #PostgreSQL:
>> PQINCPATH =
>> PQLIBPATH = -L/usr/lib -L/usr/local/lib
>> PQLIB =
>> #ODBC:
>> ODBCINC =
>> #Image formats:
>> PNGINC = -I/usr/X11R6/include/ -I/usr/include/gr
>>-I/usr/local/include -I/usr/include
>> PNGLIB = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
>> #JPEGINCPATH = -I/usr/X11R6/include/ -I/usr/include/gr
>> #JPEGLIBPATH = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
>> JPEGINCPATH =
>> JPEGLIBPATH =
>> JPEGLIB =
>> TIFFINCPATH = -I/usr/local/include
>> TIFFLIBPATH = -L/usr/local/lib
>> #openGL files for NVIZ/r3.showdspf
>> OPENGLINC = -I/usr/local/include/GL -I/usr/X11R6/include/GL
>> OPENGLwINC =
>> OPENGLLIB = -L/usr/lib -L/usr/local/lib -L/usr/lib/X11
>>-L/usr/X11R6/lib -lGL
>> OPENGLULIB =
>> LGLWM =
>Don't think that NVIZ compiles with this settings. OPENGLULIB is -lGLU
>and LGLWM -lGlw on my linux machine.
>Is there an OpenGL port for Mac OS X? Did you install Mesa?
Is Mesa not an OpenGL port? Yes, I have installed Mesa. Should I
reinstall it?
> > #tcl/tk stuff
>> TCLINCDIR = -I/usr/local/include
>> TKINCDIR = -I/usr/local/include
>> TCLTKLIBPATH = -L/usr/local/lib
>> TCLTKLIBS =
>Hmm. TCLTKLIBS is -ltk8.3 -ltcl8.3 on Linux. Did you update the CVS
>tree?
Affirmative. I am using tcl/tk 8.0.4 because that is what is linked
to the GRASS 5 site. Should I install tcl/tk 8.3 or the latest
available release?
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
