[GRASS5] html docs from tcltkgrass + proposal
Justin Hickey jhickey at hpcc.nectec.or.th
Sun Dec 3 22:01:51 EST 2000
Hi Markus, and Andreas
Markus Neteler wrote:
> On Fri, Dec 01, 2000 at 01:33:29PM +0700, Justin Hickey wrote:
> > Therefore, I
> > propose we remove the version numbers from directory names and
> > filenames. What do people think?
> Probably this is a good proposal. Only we have to avoid confusion with
> grass4.x.
> > While I'm at it I will make one more proposal. Throughout the code
> > and documentation, the .grassrc5 file is almost always referred to
> > as the "gisrc file". Does anyone object to changing the name from
> > .grassrc to .gisrc? Of course, this change will be for 5.1.
> Mhhh, why not keeping the program's name within the filename?
Andreas Lange wrote:
> The .grassrc file is from grass4.x, whilst the .grassrc5 is from
> grass5.
> So changing from .grassrc5 to .grassrc would interfere with grass4.3.
> I have a grass4.3 setup (including a partly working xgrass) installed.
> But changing to .gisrc would be ok, although i like to have the name
> of the application in the name of the rc-file. But as always that is
> nothing fundamental.
OK, having the filename be .grassrc is fine and makes more sense. I
guess I was brainwashed after seeing it called gisrc so much in the
initialization stuff. :)
As for removing the version number, the conflict with grass4.3 was the
reason I suggested we leave it for 5.1. I assumed that once we released
Grass 5 stable, that most (if not all) users would switch to grass 5.
Then for grass 5.1, the conflict wouldn't exist. Or do you see people
still using both versions after Grass 5.1?
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
