[GRASS5] closing monitors by click
James Cameron
quozl at us.netrek.org
Sun Dec 3 16:30:28 EST 2000
On Fri, Dec 01, 2000 at 01:27:49AM -0800, Eric G . Miller wrote:
> This leads me to believe it's blocked on an open() or read() on the _rfd
> fifo file descriptor. I haven't quite tracked it down, but I'm
> confident that's part of the problem.
If the platform in question has a symbolic debugger (like gdb), then use
it to attach to the running process, then get a stack trace to find out
where it is up to.
James Cameron mailto:quozl at us.netrek.org http://quozl.netrek.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
