[GRASS5] configure.in Wants testers...
Eric G . Miller egm2 at jps.net
Sun Dec 3 16:02:03 EST 2000
On Mon, Dec 04, 2000 at 06:52:01AM +1000, Mike Thomas wrote:
> Hi Eric.
> Configure is now much better for Cygwin builds thank you.
> However:
> Under Cygwin, autoconfig should choose "bison -y" instead of "yacc".
Well, there should be some method under cygwin where "yacc" can be used
since that is the "official" name of the utility.  But I can look into
it.
> It also doesn't find the opengl libraries.  (Seems to be looking for GL/*
> instead of gl/* etc, ie capital letters instead of lower case.)
The headers are often in /usr/include/GL/ on many systems.  I don't know
why that isn't the case on Cygwin.  Try passing the
--with-opengl-includes=/path/to/gl directive.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
