[GRASS5] cygwin/windows port
Mike Thomas
mthomas at gil.com.au
Sun Dec 3 15:48:33 EST 2000
Hi Andreas.
> without any problems.
There are still autoconfig problems
- Needs to choose "bison -y" instead of "yacc".
- Doesn't find openGL libraries.
>Thanks to John Huddleston for his great work.
Yes!
> - compile the source as it is under cygwin, including the XDRIVER for
> graphics and install the Cygwin port of X11R6.4. This has the problem
> that you use grass from an X Window server on Windows, which is
> unfamiliar to windows users. And the X11R6.4 port is beta only,
> complicated to install and crashes sometimes. And i haven't seen a
> tcl/tk port for X Window under Windows yet. So tcltkgrass does not work
> right now. Only commandline/XDRIVER.
Is there a fifo implementation yet? My understanding is that none of this
will work without it.
> - compile under cygwin, create a new windows graphics DRIVER, use
> tcltkgrass with the Windows-wish (cygwish).
> I can start tcltkgrass with the cygwish with some modifications. This
> would not require to install the X11 system and would run in the windows
> graphics, which is a big advantage (familiar usage).
> Writing a graphics driver for windows should not be too complicated for
> a windows programmer (i can assist as i already wrote a new driver for
> GRASS). But i don't know if it is possible to compile this driver
> without MS Visual C++. The headers and API is there, e. g. the cygwish
> port uses this setup.
As you say, Cygwin has Windows API headers. I'm not sure what the driver
would need that you would need MSVC++ for. There is also the mingw compiler
(gcc without Cygwin).
If the fifo problem is not an issue, please tell me what to do to make a
driver, and I will think about building one. I am unsure of how much time I
will have over the next two months, but I can at least work out what is
required.
Cheers
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
