[GRASS5] html docs from tcltkgrass + proposal
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Dec 1 14:18:21 EST 2000
Hi Justin,
Justin Hickey wrote:
> Hello all
> Andreas Lange wrote:
> > I would not recommend to remove the .tcltkgrass file, as it will
> > remove all user configuration (fonts, window sizes, open windows/x
> > drivers). This is not the usual behaviour of any application i know.
> I agree.
> > If we do radical changes on the .tcltkgrass format/internals, we
> > should set up a new filename (e. g. .tcltkgrass5 ).
> Unfortunately, I would advise against this. I would suggest that writing
> a conversion script is a better way to handle this. All it requires is a
> tcltkgrass version as the first line of .tcltkgrass and a small script
> to make any necessary changes. Then when the tcltkgrass module is
> compiled, it checks for a .tcltkgrass file, checks the version, then
> performs the proper substitutions to create an up to date file. At least
> this method seems to be used in other programs I've used.
OK, a conversion script would be even better. But at this time i can not
see why we should change the .tcltkgrass - format at all. Except from
the new directory for the html-files nothing changed until now.
> While I'm at it I will make one more proposal. Throughout the code and
> documentation, the .grassrc5 file is almost always referred to as the
> "gisrc file". Does anyone object to changing the name from .grassrc to
> .gisrc? Of course, this change will be for 5.1.
The .grassrc file is from grass4.x, whilst the .grassrc5 is from grass5.
So changing from .grassrc5 to .grassrc would interfere with grass4.3. I
have a grass4.3 setup (including a partly working xgrass) installed.
But changing to .gisrc would be ok, although i like to have the name of
the application in the name of the rc-file. But as always that is
nothing fundamental.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
