[GRASS5] configure.in Wants testers...
Jeshua Lacock
jeshua at SierraMaps.com
Sat Dec 2 03:56:59 EST 2000
On Saturday, December 2, 2000, at 12:02 AM, Eric G . Miller wrote:
> > Everything looks good here on MacOS X (I don't have to remove the -lm
> > switches anymore :-D ) except for the following:
> > configure: warning: *** Failed to find Tcl/Tk libraries [...snip...]
> > checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Didn't
> > find GL/GLwMDrawA.h
> > Note that with beta 8 it gave a similar message tcl/tk message,
> > however the tcl/t interface works...
> Well, those errors really should/do matter now. The OpenGL stuff is
> really only important for NVIZ and showdspf. You may need to specify
> one of the flags to configure so it knows where to search for your
> Tcl/TK includes in libraries. There will be no linker flag for any
> compiled code against Tcl/Tk otherwise (again thinking this may only
> matter for NVIZ since I think TclTkGrass is all interpreted scripts, so
> if wish is found, it's okay).
Hi Eric!
OK, I tried to run
> ./configure --with-tcltk-libs=/usr/local/lib/
^^ where my tcl/tk directories are located
And I get the same error. Any thoughts? I would like to get NVIZ complied (mostly for others)...
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
