Fwd: Re: [GRASS5] New MacOS X compilation errors
Jeshua Lacock
jeshua at SierraMaps.com
Sat Dec 2 03:39:13 EST 2000
On Thu, Nov 30, 2000 at 02:18:04AM -0800, Markus Neteler wrote:
> Hi Jeshua,
> please
> cvs update src/display/devices/XDRIVER
> cd src/display/devices/XDRIVER
> gmake5
> and send the errors. Please add, if the references to
> > > __XErrorFunction
> > > __XIOErrorFunction
> > > __Xdebug
I just updated the entire tree and In order to compile connect.c, I had to move connect.c.orig to connect.c. The errors I got were a bunch of messages like "connect.c:73: illegal expression, found `<<'" (I have a hunch that it is checked out our something...).
I got some errors about malloc and realloc, so I deleted line 1369 in SWITCHER.c to get it working.
Here is the errors for XDRIVER/XDRIVER24:
/usr/src/grass/src/display/devices/XDRIVER/XDRIVER24
make -f OBJ.powerpc-apple-darwin1.2/make.rules
cc -o /usr/local/grass5/driver/XDRIVER OBJ.powerpc-apple-darwin1.2/SWITCHER.o OBJ.powerpc-apple-darwin1.2/Box_abs.o OBJ.powerpc-apple-darwin1.2/Can_do.o OBJ.powerpc-apple-darwin1.2/Color.o OBJ.powerpc-apple-darwin1.2/Cont_abs.o OBJ.powerpc-apple-darwin1.2/Clr_table.o OBJ.powerpc-apple-darwin1.2/Draw_line.o OBJ.powerpc-apple-darwin1.2/Get_w_box.o OBJ.powerpc-apple-darwin1.2/Get_w_line.o OBJ.powerpc-apple-darwin1.2/Get_w_pnt.o OBJ.powerpc-apple-darwin1.2/Graph_Clse.o OBJ.powerpc-apple-darwin1.2/Graph_Set.o OBJ.powerpc-apple-darwin1.2/Panel.o OBJ.powerpc-apple-darwin1.2/Plylne_abs.o OBJ.powerpc-apple-darwin1.2/Polygn_abs.o OBJ.powerpc-apple-darwin1.2/Returns.o OBJ.powerpc-apple-darwin1.2/Serve_Xevent.o OBJ.powerpc-apple-darwin1.2/alloc.o OBJ.powerpc-apple-darwin1.2/command_pend.o OBJ.powerpc-apple-darwin1.2/Raster.o ./lib/LIB.powerpc-apple-darwin1.2/driverlib.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libD.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a -L/usr/X11R6/lib -lSM -lICE -lX11
/usr/bin/ld: Undefined symbols:
__XErrorFunction
__XIOErrorFunction
__Xdebug
make[1]: *** [/usr/local/grass5/driver/XDRIVER] Error 1
make: *** [all] Error 2
On Thu, Nov 30, 2000 at 02:18:04AM -0800, Markus Neteler also wrote:
> are missing the results of
> grep XErrorFunction /usr/include/X11
> grep XIOErrorFunction /usr/include/X11
> grep Xdebug /usr/include/X11
> and send this as well. Then we might to find the problem.
> It's strange that you could compile the beta8 driver. Nothing has
> been changed in this issue...
> Markus
Markus- Here you are (Note that the X11 include directory is located at "/usr/X11R6/lib/" not "/usr/include/X11" so I made symbolic link to see if it would help, it didn't):
> [localhost:display/devices/XDRIVER] root# grep XErrorFunction /usr/X11R6/lib/*
Binary file /usr/include/X11/libX11.a matches
> [localhost:display/devices/XDRIVER] root# grep XIOErrorFunction /usr/X11R6/lib/*
> [localhost:display/devices/XDRIVER] root# grep Xdebug /usr/X11R6/lib/*
Anything else to try?
> On Thu, Nov 30, 2000 at 02:18:04AM -0800, Jeshua Lacock wrote:
> > Markus said:
> > > On Tue, Nov 28, 2000 at 10:40:29AM -0800, Jeshua Lacock wrote:
> > > >Hi Jeshua,
> > > >another one for you :-) Hope you don't mind.
> > > >Is the Xdriver compiling? And: is it in published beta8?
> > > >Otherwise it would be fully useless!
> > > Hello Markus!
> > > Yes, the xdriver was compiled and published with beta 8, however I
> > > cannot get it to compile at this time....
> > Mhh, that's strange. Please send me some error messages. We should
> > get it compile asap. (I want to get out beta9!).
> > Here's the XDRIVER thread:
> > Begin forwarded message:
> > > From: Jeshua Lacock <jeshua at SierraMaps.com>
> > > Date: Tue Nov 21, 2000 11:37:28 PM US/Pacific
> > > To: grass5 at geog.uni-hannover.de
> > > Subject: Re: [GRASS5] New MacOS X compilation errors
> > > X-Mailer: Apple Mail (2.337)
> > > Howdy folks,
> > > On Tue, Nov 21, 2000 at 07:59:32PM +0000, Markus Neteler wrote:
> > Hi Jeshua and all,
> > > I have updated all malloc -> G_malloc in
> > cvs up
> > gmake5 src/display/devices/XDRIVER
> > Please
> > > tell me if it is o.k. now.
> > > OK, I updated the source and ran gmake5.
> > > And I got a bunch or errors like: SWITCHER.c:1396: illegal expression, found `>>'
> > > So, I edited the SWITCHER.c file and deleted the lines that were <<<<<<<<, =========.
> > > >>>>>>> and deleted the old malloc statements to get to the next step.
> > > Then, I ran gmake5 again to get these errors:
> > > SWITCHER.c: In function `xalloc':
> > > SWITCHER.c:1369: conflicting types for `malloc'
> > > /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:121:
> > > previous declaration of `malloc'
> > > SWITCHER.c:1369: warning: extern declaration of `malloc' doesn't match global one
> > > SWITCHER.c:1369:
/System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:125:
> > > previous declaration of `realloc'
> > > SWITCHER.c:1369: warning: extern declaration of `realloc' doesn't match global one
> > > make[1]: *** [OBJ.powerpc-apple-darwin1.2/SWITCHER.o] Error 1
> > > So then I edited SWITHCER.c again and deleted line 1369 (where mallox and realloc were
> > > re-defined).
> > > Raster.c: In function `Raster_int':
> > > Raster.c:83: warning: assignment from incompatible pointer type
> > > Raster.c:85: warning: assignment from incompatible pointer type
> > > cc -o /usr/local/grass-5.0b/driver/XDRIVER
> > > /usr/src/grass/grass/src/libes/LIB.powerpc-apple-darwin1.2/libD.a
> > > /usr/src/grass/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a
> > > __XErrorFunction
> > > __XIOErrorFunction
> > > __Xdebug
> > > make[1]: *** [/usr/local/grass-5.0b/drive
Error 2
> > > At which point I get stumped! (Heeeeelp!)
> > > Jeshua Lacock
> > Jeshua Lacock
> Dipl.-Geogr. Markus Neteler * University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494 Fax: -3984
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
