[GRASS5] configure.in Wants testers...
Eric G . Miller
egm2 at jps.net
Sat Dec 2 03:02:05 EST 2000
On Fri, Dec 01, 2000 at 11:11:14PM -0800, Jeshua Lacock wrote:
> Everything looks good here on MacOS X (I don't have to remove the -lm
> switches anymore :-D ) except for the following:
> configure: warning: *** Failed to find Tcl/Tk libraries [...snip...]
> checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Didn't
> find GL/GLwMDrawA.h
> Note that with beta 8 it gave a similar message tcl/tk message,
> however the tcl/t interface works...
Well, those errors really should/do matter now. The OpenGL stuff is
really only important for NVIZ and showdspf. You may need to specify
one of the flags to configure so it knows where to search for your
Tcl/TK includes in libraries. There will be no linker flag for any
compiled code against Tcl/Tk otherwise (again thinking this may only
matter for NVIZ since I think TclTkGrass is all interpreted scripts, so
if wish is found, it's okay).
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
