[GRASS5] Notes on compiling beta6f on ALPHA
Luca Palmeri lpalmeri at ux1.unipd.it
Fri Jan 7 09:15:06 EST 2000
Thanks to Bill for the 64bit PVF. I will test it. For the moment being
I have compiled
beta6f on the alpha. With CC I get the following error, right in the
beginning of compilation:
  /export/venus6b/grass/src/src/raster/r.proj/cmd
    mkdir OBJ.alphaev56-dec-osf4.0d
    make -f OBJ.alphaev56-dec-osf4.0d/make.rules
  rm -f OBJ.alphaev56-dec-osf4.0d/main.o
  cc -g   -I/export/venus6b/grass/src/src/include  -c main.c
  cc: Error: /export/venus6b/grass/src/src/include/gisdefs.h, line 278:
Invalid declaration.
  int G_fatal_error(char *,...) __attribute__ ((__noreturn__));
This error does not appear with GCC.  With this latter compiler however
I had to
exclude i.in.erdas due to the following error:
  GISGEN: src/imagery/i.in.erdas - Wed Jan 5 19:14:27 MET 2000
  main.c:48: conflicting types for `swab'
/usr/local/lib/gcc-lib/alphaev56-dec-osf4.0d/2.8.0/include/unistd.h:183:
previous declaration of `swab'
All of the other stuff is compiled without problems either with either
compilers.
Luca
--> Luca Palmeri - Dip. Proc. Chimici dell'Ingegneria
    Universita' di Padova  TEL: +390498275527 -------
-------------------------  FAX: +390498275528 -------
--> Think holistic @ the end of the 2nd millenium <--
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2330
max: 0
