[GRASS5] Notes on compiling beta6f on ALPHA
Angus Carr
acarr at iname.com
Fri Jan 7 13:37:45 EST 2000
Thank you for testing i.in.erdas on a 64-bit platform.
I am fairly sure it won't work properly, but I would appreciate hearing
back about it.
I will fix the compile error soon, and hopefully make it into a 64-bit
compatible program.
Angus Carr.
Luca Palmeri wrote:
> Thanks to Bill for the 64bit PVF. I will test it. For the moment being
> I have compiled
> beta6f on the alpha. With CC I get the following error, right in the
> beginning of compilation:
> /export/venus6b/grass/src/src/raster/r.proj/cmd
> mkdir OBJ.alphaev56-dec-osf4.0d
> make -f OBJ.alphaev56-dec-osf4.0d/make.rules
> rm -f OBJ.alphaev56-dec-osf4.0d/main.o
> cc -g -I/export/venus6b/grass/src/src/include -c main.c
> cc: Error: /export/venus6b/grass/src/src/include/gisdefs.h, line 278:
> Invalid declaration.
> int G_fatal_error(char *,...) __attribute__ ((__noreturn__));
> This error does not appear with GCC. With this latter compiler however
> I had to
> exclude i.in.erdas due to the following error:
> GISGEN: src/imagery/i.in.erdas - Wed Jan 5 19:14:27 MET 2000
> main.c:48: conflicting types for `swab'
> /usr/local/lib/gcc-lib/alphaev56-dec-osf4.0d/2.8.0/include/unistd.h:183:
> previous declaration of `swab'
> All of the other stuff is compiled without problems either with either
> compilers.
> Luca
> --> Luca Palmeri - Dip. Proc. Chimici dell'Ingegneria
> Universita' di Padova TEL: +390498275527 -------
> ------------------------- FAX: +390498275528 -------
> --> Think holistic @ the end of the 2nd millenium <--
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 2330
> max: 0
length: 2836
max: 0
