[GRASS5] GRASS in Windows95/98
BRADLEY HARRISON
bradley.harrison at usa.net
Sun Jul 30 03:05:19 EDT 2000
Do I still need all the other bits such as g77 and X11R6.4 to get GRASS to
work or all I need is the preconfigured downloads?
For the moment all I need is to get the rast.to.vect to work. Though I
would like to get a DEM going, but without a monitor it may not be much use.
yours
Bradley Harrison
John Huddleston <jhudd at lamar.colostate.edu> wrote:
> hi Bradley,
> Many of the grass data manipulation functions
> are available for windows. The monitor (or
> display) is not yet available. I have not tried
> the Tcl/Tk interface yet though.
> You will have to install either the older Cygwin
> B20.1 distribution or the newer version 1.1.2
> in order to get the "unix" commands and DLLs
> required to run grass under Windows.
> The ZIP distribution looks for executables under the
> /usr/local/grass-5.0b area. Forward slashes only make
> sense when using Cygwin.
> John Huddleston
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
____________________________________________________________________
Get free email and a permanent address at http://www.netaddress.com/?N=1
If you want to unsubscribe from GRASS Development Team mailing list write to:
