[GRASS5] Re: [Re: info grass5]
John Huddleston
jhudd at lamar.colostate.edu
Sat Jul 29 16:33:56 EDT 2000
hi Bradley,
Many of the grass data manipulation functions
are available for windows. The monitor (or
display) is not yet available. I have not tried
the Tcl/Tk interface yet though.
You will have to install either the older Cygwin
B20.1 distribution or the newer version 1.1.2
in order to get the "unix" commands and DLLs
required to run grass under Windows.
The ZIP distribution looks for executables under the
/usr/local/grass-5.0b area. Forward slashes only make
sense when using Cygwin.
John Huddleston
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
