[GRASS5] g++
Robert Lagacé lagace at echo.grr.ulaval.ca
Fri Jul 28 15:07:31 EDT 2000
Francisco Alonso wrote:
> Hi :
> I'm in my first attempts to program with GRASS libraries, this is my
> first query to the list as well. So it is probably a little naive.
> Apologizes.
> The GRASS source code I've seen seems to be C and not C++. I've tried to
> compile C++ stuff just adding CC=g++ in the GMakefile but it gives
> errors that seems related with the GRASS datatypes. What I'm doing
> wrong?
There some differences between C and C++ in data type.  So use CC=gcc instead.
You will use the C compiler and syntax.
> Thanks in advance for any help.
> Francisco Alonso
> Geography Department
> King's College London
> UK
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
