[GRASS5] Error in trying to compile for SGI
Justin Hickey jhickey at impact1.hpcc.nectec.or.th
Thu Jul 27 13:12:07 EDT 2000
Hello all
I am trying to compile a set of binaries for SGI and have found the following
error:
/usr/people/jhickey/grassCVS/grass/src/mapdev/v.rmdup/cmd
  mkdir OBJ.mips-sgi-irix6.5
  make -f OBJ.mips-sgi-irix6.5/make.rules
"rmdup.c", line 194: error(1565): struct "__file_s" has no field "_shortbuf"
      while (match == 0 && Closet->dig_fp->_shortbuf[1])  /* try to upgrade in
5/2000 */
The actual code snippet is as follows:
/* commented following "while line" 5/2000:
 *   dig_fp->_cnt was once defined in _IO_FILE_ /usr/include/libio.h
 *   int _cnt;    "number of characters in the buffer"
 * -> but today?
 /*     while (match == 0 && Closet->dig_fp->_cnt) */
#ifndef __CYGWIN__
5/2000 */
#else
    while (match == 0 && Closet->dig_fp->_bf._size)
#endif
The comment says that dig_fp->_cnt is no longer defined. That may be true for
Linux, but not for Irix. It is still defined and worse, _shortbuf is not
defined.
The appropriate FILE struct on Irix is as follows
typedef struct	/* needs to be binary-compatible with old versions */
#if (_SGIAPI && _NO_ANSIMODE) || defined(_LANGUAGE_C_PLUS_PLUS)
 * The __file_s struct tag is for backwards compat ONLY - it shouldn't be
 * used in any new headers. We would have liked to not use it in C++ since
 * it will change the name mangling of FILE *, but since it has already
 * gone out that way, we must stick to it. The safest thing is to *always*
 * define it for C++ (since a function that takes a FILE * as an argument
 * will have this tag in its mangled name).
__file_s
#endif
#if (_MIPS_SZLONG == 32)
	int		_cnt;	/* number of available characters in buffer */
#endif
#if (_MIPS_SZLONG == 64)
	long		_cnt;	/* number of available characters in buffer */
#endif
	unsigned char	*_ptr;	/* next character from/to here in buffer */
	unsigned char	*_base;	/* the buffer */
#if _MIPS_SIM == _ABI64
	unsigned char	_reserved[2]; /* MIPS ABI */
	unsigned short	_flag;	/* the state of the stream */
	unsigned int	_file;	/* UNIX System file descriptor */
#elif _MIPS_SIM == _ABIN32
	unsigned char	_flag;	/* the state of the stream */
	unsigned char	_o_file;	/* not used */
	unsigned short	_file;	/* UNIX System file descriptor */
#else	/* _MIPS_SIM == _ABIO32 */
	unsigned char	_file;	/* UNIX System file descriptor */
#endif
} FILE;
Anyone have any suggestions how to fix this? I have no idea at all.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
