[GRASS5] d.dm
Radim Blazek
Radim.Blazek at dhv.cz
Wed Jul 19 06:22:41 EDT 2000
Justin Hickey wrote:
> Hi Radim
> On Jul 17, 9:37am, Radim Blazek wrote:
> > Subject: Re: [GRASS5] d.dm
> > > thank you very much for the display manager.
> > > I like the concept and think that it could be expanded to a fully
> > > functional "Map Manager" in GRASS.
> > > I had some time ago the idea of a similar program, but no time to spent
> > > on it. My idea was slightly different, i think one should use a
> > > tree-like widget to display the items to display in one window (with the
> > > Set as the root, no need to display more than one set at a time). The
> > > window on the right could contain an entry widget with all the options
> > > for the currently selected display item,
> > I will think about tree+entry (d.dm window displays also something
> > like legend (color(s), icon,..) and so tree should contain these items.
> > Changing color would require 3 clicks instead of 2)
> If you are interested in creating a tree widget, then you should look into the
> $GISBASE/bwidget Tcl/Tk library. It includes functions to create a tree widget
> and may be useful to you. I haven't used the tree widget myself, but I am using
> other bwidget features for the Tcl/Tk version of v.digit, as well as the new
> initialization routines. There are README files in the bwidget directory that
> inform you how to use bwidget with GRASS as well as how to run the demo scripts
> and find the html man pages.
> I'm sorry I did not have time to try your code, and this suggestion could be
> totally off-base. I just thought this may be useful to you.
Almost everything in d.dm is based on BWidget.
Thank you for commiting BWidget into GRASS source.
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
