[GRASS5] v.out.e00 is ready
B. Byars
Bruce_Byars at baylor.edu
Fri Jun 16 10:15:46 EDT 2000
Michel,
Shoot this to Lisa here (Lisa_Zygo at baylor.edu). She's got
arcinfo on her desktop. I'm compiling th code now. We'll
try it out today.
Bruce
Michel Wurtz - ENGEES/CEREG wrote:
> Dear Markus (and others),
> After two long night, I finaly have something that mimics (as far
> as I know) the e00 format. The boring thing was to create the
> "universe" polygon beloved by Arc/Info.
> I would be glad if some Arc/Info owner can test the output.
> I something doesnt work, I will like to have an original e00
> file of a simple drawing (2 polygons, on with a hole, and an
> external isle) with straigth lines, so it's easy to import and
> export and to compare both.
> v.out.e00 use the Grass dig_att file for filling the attribute of
> the coverage-ID, so if it is linked to an external database via the
> attribute, you should get all of them in Arc/Info.
> Here is the program, the Gmakefile and the manual page in html.
> Michel Wurtz ENGEES - CEREG
> 1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
> Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
> v.out.e00.tgz Type: WinZip File (application/x-compressed)
> Encoding: base64
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
