[GRASS5] G_fatal_error question
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jun 16 06:07:27 EDT 2000
Dear developers,
currently Roger Bivand is improving his "R"-GRASS
interface. You can use R within GRASS, load a
R-GRASS library and bidirectional exchange data
between GRASS and R for analysis.
So far, so good, but he is facing following problem:
Roger wrote:
>I think the compiled
>interface is going to work, though I'm still worried about
>G_fatal_error(), which kills R too. It would be nice to have a function to
>turn it off when GRASS libraries are being linked into dynamically loaded
>modules in other settings, or at least to stop it doing exit(). Maybe
>there is one? (Not the handler, because that doesn't stop the exit().)
Do you have any ideas to help him?
Many thanks in advance
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
