[GRASS5] Help:how to run 3d_module on alpha(compaq ds-10)
박재영 asadall at ksic.net
Fri Jun 16 03:27:18 EDT 2000
Thanks for replying my mail....^_^
I have an Alpha DS10 running Redhat Linux (kernel 2.2.14-14) and...
compiler is 'gcc (egcs-1.1.2)'.
Your help would be greatly appreciated!
Thanks!
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, June 16, 2000 2:56 PM
Subject: Re: [GRASS5] Help:how to run 3d_module on alpha(compaq ds-10)
> On Fri, Jun 16, 2000 at 01:22:34PM +0900,  wrote:
> > I'm a student studying the Grass.. but,
> > d.3d module doesn't run with spearfish database on the
alphaserver(compaq ds10).
> > The error message is followed:
> >    'Floating point exception'
> > and exit module.
> > I think that the module doesn't run because spearfish data is not
64-bit.
> > Tell me how to run 3d module ....
> I have the resources to fix this, I just haven't explored it yet.
> I work for Compaq and I have an Alpha running Debian Linux, and another
> running Compaq Tru64 UNIX.  Which operating system were you using on the
> DS10 to generate this error?  Which compiler?
> I need to spend a few moments starting up a cvs checkout, as soon as I
> find where the CVS server is and what the anon login is.  ;-)
> James Cameron    mailto:quozl at us.netrek.org     http://quozl.netrek.org/
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ!ü¨»§¶Ú.žË›±Êâmçë¢a‘$ƒz÷¥¢™žžÔÞjišŠX§‚X¬·
âµëhþh§¢·hšàzˆÿºxÿ…©ç¢÷«ý×°ŠØl¹¸ÞrßîžË›±Êâmè+jË9
