[GRASS5] Help:how to run 3d_module on alpha(compaq ds-10)
James Cameron
quozl at us.netrek.org
Fri Jun 16 01:56:13 EDT 2000
On Fri, Jun 16, 2000 at 01:22:34PM +0900, wrote:
> I'm a student studying the Grass.. but,
> d.3d module doesn't run with spearfish database on the alphaserver(compaq ds10).
> The error message is followed:
> 'Floating point exception'
> and exit module.
> I think that the module doesn't run because spearfish data is not 64-bit.
> Tell me how to run 3d module ....
I have the resources to fix this, I just haven't explored it yet.
I work for Compaq and I have an Alpha running Debian Linux, and another
running Compaq Tru64 UNIX. Which operating system were you using on the
DS10 to generate this error? Which compiler?
I need to spend a few moments starting up a cvs checkout, as soon as I
find where the CVS server is and what the anon login is. ;-)
James Cameron mailto:quozl at us.netrek.org http://quozl.netrek.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
