[GRASS5] Prototype Oracle 8 tools
Radim Blazek
Radim.Blazek at dhv.cz
Tue Jun 13 16:07:39 EDT 2000
Markus Neteler wrote:
> Hi all,
> today I checked in two prototype Oracle 8.x modules from
> > Beside that a new ODBC driver is there (db.* modules), I connected to
> > PostgreSQL as well (should work with Oracle, too). It is using
> > unixODBC.
> universal, reliable, portable, but not so fast as a custom solution...I really
> don't know what's the best way.
> (As you can understand i'm a performance maniac!)
Note about DBMI (db.* modules): DBMI != ODBC
DBMI is GRASS library for writing RDBMS modules and drivers.
You can write your own driver for Oracle or Postgres
but share all db.* modules with users of other RDBMS.
(I know it is also bit slower) . I started to work on dbmi because I think
it is better solution than:
d.rast.pg d.what.r.pg g.column.pg g.table.pg v.in.arc.pg
d.site.pg d.what.s.pg g.select.pg pg.in.dbf v.in.shape.pg
d.vect.pg d.what.v.pg g.stats.pg v.reclass.pg
d.rast.inf d.what.r.inf g.column.inf g.table.inf r.rescale.inf
d.site.inf d.what.s.inf g.select.inf v.reclass.inf
d.vect.inf d.what.v.inf g.stats.inf r.reclass.inf
d.vect.ora d.what.v.ora g.stats.ora r.rescale.ora
d.rast.ora d.what.r.ora g.column.ora g.table.ora v.reclass.ora
d.site.ora d.what.s.ora g.select.ora r.reclass.ora
and so on for each RDBMS.
But it's only my opinion.
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
