[GRASS5] Compile Grass 5 on Win 32
Mike Thomas mthomas at gil.com.au
Tue Jun 6 10:06:48 EDT 2000
Hi John.
>I upgraded from B20.1 to the new cygwin1.1.1 in order
>to use the rsh for cvs access to the repository.  So, your
>system is different.  The original zip file that I gave to
>Markus was B20 but all recent builds use Cygnus1.1.1
>Unless you upgrade, I cannot help you.
Thats unfortunate, as the 1.1.1 distribution GPF's all the time!  Maybe I'd
better stick to binary distributions.
>The memory leak may be because you have older b20.1
>1998 tools with the latest cygwin1.dll.  I would stick
>with Mumit's cygwin1.dll from his gcc distribution if
>you are using B20.1
OK.
>Get the rpc library and include files off Corinna's
>site for the Xdr.
>ftp://ftp.franken.de/pub/win32/develop/gnuwin32/cygwin/porters/Vinschen_Cor
i
>nna/B20/
The XDR problem turned out to be Gmakefiles which did not use the XDRLIB
macro.
>See http://cygutils.netpedia.net/V1.1/ for ipc.
>Yes, I use ansi TERM, too.
Unfortunately g.help is still hanging, presumably not a TERM problem then.
Thanks
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
