[GRASS5] Compile Grass 5 on Win 32
John Huddleston jhuddleston at itc.nrcs.usda.gov
Tue Jun 6 09:13:11 EDT 2000
I upgraded from B20.1 to the new cygwin1.1.1 in order
to use the rsh for cvs access to the repository.  So, your
system is different.  The original zip file that I gave to
Markus was B20 but all recent builds use Cygnus1.1.1
Unless you upgrade, I cannot help you.
The memory leak may be because you have older b20.1
1998 tools with the latest cygwin1.dll.  I would stick
with Mumit's cygwin1.dll from his gcc distribution if
you are using B20.1
Get the rpc library and include files off Corinna's
site for the Xdr.
ftp://ftp.franken.de/pub/win32/develop/gnuwin32/cygwin/porters/Vinschen_Cori
nna/B20/
See http://cygutils.netpedia.net/V1.1/ for ipc.
Yes, I use ansi TERM, too.
John Huddleston
----- Original Message -----
To: grass5 <grass5 at geog.uni-hannover.de>
Sent: Monday, June 05, 2000 4:09 PM
Subject: Re: [GRASS5] Compile Grass 5 on Win 32
> Hi John.
> Thanks for the replies - this has been an interesting journey through the
> Cygwin tools on Windows 98.
> >Read the INSTALL file.  You must do the configure first.
> Did that.  The problem was the version of Cygwin.  I found that by
starting
> with the B20 installation, updating to GCC 2.95.2 from Mumit Khan's site,
> updating BASH to 2.04, updating Cygwin DLL to the version which comes out
of
> the Cygwin "latest" setup.exe program (definitely *not* the one which
> setup.exe installs off the internet as they are different, and the latter
> version causes make to have the problems I reported) I was able to get a
> compile of sorts.
> Restarted the computer mid compile because the Cygwin tools have a bad
> memory leak!
> >The mkfifo command under Cygwin is not operational yet.
> >It is scheduled to be done this summer.  Everything else
> >builds.
> I got most of it to build bar the NVIZ and 3d stuff at the end, although
the
> xdr functions were not picked up during links, so I'll investigate further
> tonight.
> Grass does not recognise the cygwin TERM, I have to set it to ansi!
> Grass freezes if I try and run g.help or s.in.ascii.  Any ideas?
> Cheers
> Mike Thomas.
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
