[GRASS5] s.in.shape
David D Gray
ddgray at armadce.demon.co.uk
Mon Jun 5 16:44:05 EDT 2000
Hi everyone
A module to import point and multipoint type shapefiles to a
GRASS sites list is now in CVS. It seems to function for simple
sites, but has not been extensively tested.
But there is a problem: in the file I have included below, only the
first five sites are displayed by d.sites. When the extra fields are
removed (which I did by a simple sed command), so that only the
attribute field remains, it displays OK. Is there a problem with
d.sites?
David
name|rbi
desc|Imported from points shapefile rbi.shp.
time|
330250|569850|200|#625 %1 %625 %0 %1 %0 %1 %0 %0 %0 @"Annandale & Eskdale" @NY302698 @- @21 @A @A @0 @0 @330250 @569850
331050|570250|200|#640 %2 %640 %0 %1 %0 %1 %0 %0 %0 @"Annandale & Eskdale" @NY310702 @- @16 @A @A @0 @0 @331050 @570250
323150|572150|200|#389 %3 %389 %0 %5 %0 %3 %0 %0 %0 @"Annandale & Eskdale" @NY231721 @- @13 @P @P @0 @0 @323150 @572150
337350|576850|200|#655 %4 %655 %0 %1 %0 %3 %0 %0 %0 @"Annandale & Eskdale" @NY373768 @- @12 @A @P @0 @0 @337350 @576850
328750|572150|200|#684 %5 %684 %0 %1 %0 %1 %0 %0 %0 @"Annandale & Eskdale" @NY287721 @- @9 @A @A @0 @0 @328750 @572150
333850|576250|200|#74 %6 %74 %0 %0 %0 %0 %0 %0 %0 @"Annandale & Eskdale" @NY338762 @"Beckhall Moss" @6 @U @U @0 @0 @333850 @576250
328450|574650|200|#290 %7 %290 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY284746 @"Branteth Flow" @50 @P @P @0 @0 @328450 @574650
326250|573750|200|#607 %8 %607 %0 %1 %0 %2 %0 %3 %0 @"Annandale & Eskdale" @NY262737 @"Burnfoothill Moss" @27 @A @P @0 @0 @326250 @573750
331850|573750|200|#332 %9 %332 %0 %2 %0 %1 %5 %5 %0 @"Annandale & Eskdale" @NY318737 @"Cadgill Flow" @24 @P @P @0 @30 @331850 @573750
332350|571750|200|#393 %10 %393 %0 %4 %0 %2 %0 %7 %0 @"Annandale & Eskdale" @NY323717 @"Cowgarth Flow" @13 @P @P @0 @0 @332350 @571750
322750|571250|200|#181 %11 %181 %0 %2 %0 %2 %0 %0 %0 @"Annandale & Eskdale" @NY227712 @"Creca Moss" @45 @S @S @0 @40 @322750 @571250
328650|573750|200|#355 %12 %355 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY286737 @"Flowdens Flow" @17 @P @P @0 @0 @328650 @573750
327450|572950|200|#250 %13 %250 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY274729 @"Gillshaw Flow" @87 @P @P @0 @0 @327450 @572950
338350|575550|200|#344 %14 %344 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY383755 @"Graystone Flow" @20 @P @P @0 @0 @338350 @575550
333050|572550|200|#350 %15 %350 %0 %2 %0 %2 %0 %6 %0 @"Annandale & Eskdale" @NY330725 @"Greenwrae Flow" @19 @P @P @0 @0 @333050 @572550
309650|581350|200|#479 %16 %479 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY096813 @"Heck Moss" @5 @P @P @0 @0 @309650 @581350
307950|579950|200|#309 %17 %309 %0 %5 %0 %4 %0 %0 %0 @"Annandale & Eskdale" @NY079799 @"Hightae Moss" @34 @P @P @0 @0 @307950 @579950
338350|577150|200|#337 %18 %337 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY383771 @"Holehouse Flow" @23 @P @P @0 @0 @338350 @577150
314050|570050|200|#300 %19 %300 %0 %5 %0 %4 %0 %0 %0 @"Annandale & Eskdale" @NY140700 @"Kelhead Flow" @38 @P @P @0 @0 @314050 @570050
332950|570050|200|#430 %20 %430 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY329700 @"Newton Flow" @9 @P @P @0 @0 @332950 @570050
326550|568550|200|#150 %21 %150 %0 %2 %0 %2 %0 %10 %0 @"Annandale & Eskdale" @NY265685 @"Nutberry Moss" @339 @S @P @0 @21 @326550 @568550
311550|566250|200|#217 %22 %217 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY115662 @"Priestside Flow" @195 @P @P @0 @0 @311550 @566250
329550|571850|200|#258 %23 %258 %0 %1 %0 %1 %60 %10 %0 @"Annandale & Eskdale" @NY295718 @"Raeburn Flow" @78 @P @P @65 @0 @329550 @571850
308150|588050|200|#265 %24 %265 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY081880 @"Redhalls Moss" @71 @P @P @0 @0 @308150 @588050
304950|581550|200|#836 %25 %836 %0 %1 %0 %1 %0 %0 %0 @"Annandale & Eskdale" @NY049815 @"Skipmyre Moss" @1 @A @A @0 @0 @304950 @581550
307550|584250|200|#384 %26 %384 %0 %5 %0 %5 %0 %0 %0 @"Annandale & Eskdale" @NY075842 @"Whitereed Wood" @14 @P @P @0 @0 @307550 @584250
304850|572750|200|#297 %27 %297 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NY048727 @- @41 @P @P @0 @0 @304850 @572750
302750|574650|200|#611 %28 %611 %0 %1 %0 %1 %0 %5 %0 @Nithsdale @NY027746 @- @26 @A @P @0 @0 @302750 @574650
299250|576750|200|#656 %29 %656 %0 %1 %0 %5 %0 %0 %0 @Nithsdale @NX992767 @- @12 @A @P @0 @0 @299250 @576750
302450|569950|200|#448 %30 %448 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NY024699 @- @7 @P @P @0 @0 @302450 @569950
298550|577150|200|#460 %31 %460 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NX985771 @- @7 @P @P @0 @0 @298550 @577150
298850|577450|200|#516 %32 %516 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NX988774 @- @3 @P @P @0 @0 @298850 @577450
298950|576550|200|#764 %33 %764 %0 %2 %0 %1 %0 %0 %0 @Nithsdale @NX989765 @- @3 @A @A @0 @0 @298950 @576550
298850|578550|200|#537 %34 %537 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NX988785 @- @2 @P @P @0 @0 @298850 @578550
300450|579050|200|#544 %35 %544 %0 %3 %0 %3 %0 %0 %0 @Nithsdale @NY004790 @- @2 @P @P @0 @0 @300450 @579050
300550|575550|200|#204 %36 %204 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NY005755 @"Craigs Moss" @1,122 @P @P @0 @0 @300550 @575550
295150|572550|200|#582 %37 %582 %0 %1 %0 %1 %0 %0 %0 @Nithsdale @NX951725 @"Drungans Moss" @126 @A @A @0 @0 @295150 @572550
298950|578150|200|#426 %38 %426 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NX989781 @"Herries Firs" @9 @P @P @0 @0 @298950 @578150
301050|570350|200|#587 %39 %587 %0 %1 %0 %1 %0 %0 %0 @Nithsdale @NY010703 @"Kelwood Moor" @71 @A @A @0 @0 @301050 @570350
297250|569850|200|#220 %40 %220 %0 %5 %0 %1 %5 %0 %0 @Nithsdale @NX972698 @"Kirkconnel Flow" @168 @P @P @142 @Y @0 @297250 @569850
304450|570550|200|#205 %41 %205 %0 %5 %0 %1 %170 %0 %0 @Nithsdale @NY044705 @"Longbridge Muir" @1,056 @P @P @514 @0 @304450 @570550
300150|579550|200|#741 %42 %741 %0 %1 %0 %1 %0 %0 %0 @Nithsdale @NY001795 @"Manse Moss" @4 @A @A @0 @0 @300150 @579550
299550|579750|200|#454 %43 %454 %0 %1 %0 %1 %7 %0 %0 @Nithsdale @NX995797 @Mossdale @7 @P @P @0 @0 @299550 @579750
310350|566750|200|#310 %44 %310 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NY103667 @"Priestside Flow" @33 @P @P @0 @0 @310350 @566750
303250|572750|200|#208 %45 %208 %0 %5 %0 %5 %0 %0 %0 @Nithsdale @NY032727 @"Racks Moss" @504 @P @P @0 @0 @303250 @572750
302550|576450|200|#585 %46 %585 %0 %1 %0 %3 %0 %15 %0 @Nithsdale @NY025764 @"Redhills Moss" @88 @A @P @0 @0 @302550 @576450
304850|581450|200|#745 %47 %745 %0 %1 %0 %1 %0 %0 %0 @Nithsdale @NY048814 @"Skipmyre Moss" @4 @A @A @0 @0 @304850 @581450
285050|561550|200|#224 %48 %224 %0 %5 %0 %2 %0 %5 %0 @Stewartry @NX850615 @"Barclosh Moss Complex" @147 @P @P @0 @0 @285050 @561550
284750|562250|200|#396 %49 %396 %0 %5 %0 %5 %0 %0 %0 @Stewartry @NX847622 @"Edingham Moss" @12 @P @P @0 @0 @284750 @562250
288050|571850|200|#161 %50 %161 %0 %1 %0 %3 %0 %25 %0 @Stewartry @NX880718 @"Merkland Moss" @107 @S @P @0 @0 @288050 @571850
280050|550350|200|#222 %51 %222 %0 %5 %0 %5 %0 %0 %0 @Stewartry @NX800503 @"Rascarrel Moss" @163 @P @P @0 @0 @280050 @550350
212050|554750|200|#578 %52 %578 %0 %2 %0 %2 %0 %15 %0 @Wigtown @NX120547 @- @259 @A @P @0 @0 @212050 @554750
211450|542450|200|#11 %53 %11 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX114424 @- @32 @U @U @0 @0 @211450 @542450
209550|553250|200|#19 %54 %19 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX095532 @- @24 @U @U @0 @0 @209550 @553250
210150|554550|200|#37 %55 %37 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX101545 @- @18 @U @U @0 @0 @210150 @554550
207750|550050|200|#52 %56 %52 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX077500 @- @11 @U @U @0 @0 @207750 @550050
239050|540750|200|#53 %57 %53 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX390407 @- @11 @U @U @0 @0 @239050 @540750
210250|541550|200|#60 %58 %60 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX102415 @- @8 @U @U @0 @0 @210250 @541550
210750|543950|200|#63 %59 %63 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX107439 @- @8 @U @U @0 @0 @210750 @543950
209050|543250|200|#70 %60 %70 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX090432 @- @7 @U @U @0 @0 @209050 @543250
210850|541250|200|#76 %61 %76 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX108412 @- @6 @U @U @0 @0 @210850 @541250
209450|554050|200|#80 %62 %80 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX094540 @- @6 @U @U @0 @0 @209450 @554050
210650|541750|200|#117 %63 %117 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX106417 @- @3 @U @U @0 @0 @210650 @541750
240650|548850|200|#271 %64 %271 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX406488 @"Airies Moss" @64 @P @P @0 @0 @240650 @548850
239450|543950|200|#241 %65 %241 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX394439 @"Auchness Moss" @113 @P @P @0 @0 @239450 @543950
206350|552650|200|#325 %66 %325 %0 %2 %0 %2 %0 %10 %0 @Wigtown @NX063526 @Barnchalloch @27 @P @P @0 @0 @206350 @552650
209150|561950|200|#40 %67 %40 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX091619 @"Baylett Moss" @16 @U @U @0 @0 @209150 @561950
200150|563750|200|#21 %68 %21 %0 %0 %0 %0 %0 %0 %0 @Wigtown @NX001637 @"Black Loch Moss" @22 @U @U @0 @0 @200150 @563750
243150|557950|200|#308 %69 %308 %0 %1 %0 %1 %25 %0 %0 @Wigtown @NX431579 @"Borrow Moss" @34 @P @P @0 @0 @243150 @557950
242850|558950|200|#260 %70 %260 %0 %1 %0 %1 %60 %0 %0 @Wigtown @NX428589 @"Carsegowan Moss" @76 @P @P @50 @0 @242850 @558950
209250|543750|200|#277 %71 %277 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX092437 @"Drumbreddan Moss" @55 @P @P @0 @0 @209250 @543750
237850|545850|200|#237 %72 %237 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX378458 @"Drumscallan Moss" @119 @P @P @0 @0 @237850 @545850
199050|564150|200|#157 %73 %157 %0 %1 %0 %1 %50 %26 %0 @Wigtown @NW990641 @"Garchrie Moss" @153 @S @P @0 @0 @199050 @564150
240850|544950|200|#242 %74 %242 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX408449 @"Grennan Moss" @111 @P @P @0 @0 @240850 @544950
243950|559650|200|#209 %75 %209 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX439596 @"Moss of Cree" @474 @P @P @0 @30 @243950 @559650
240850|542750|200|#243 %76 %243 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX408427 @"Ravenstone Moss" @108 @P @P @0 @0 @240850 @542750
207550|547150|200|#273 %77 %273 %0 %5 %0 %5 %0 %0 %0 @Wigtown @NX075471 @"Ringuinea Moss" @59 @P @P @0 @0 @207550 @547150
