[GRASS5] Poll to remove XGRASS from source
Robert Lagacé lagace at echo.grr.ulaval.ca
Mon May 29 12:19:56 EDT 2000
Andreas Lange wrote:
> Bernhard Reiter wrote:
> > On Fri, May 26, 2000 at 02:54:13PM +0100, Markus Neteler wrote:
> > > if nobody complains, I would like to remove
> > > src/xgrass/
> > > from the CVS main repository and store into a
> > > separate repository.
> > > Bernhard, Jan: is that o.k. with you?
> > You can do it, but why is a seperate repository needed?
> > Just remove it from the main branch.
> >         Bernhard
> Markus, Bernhard,
> it will be sufficent if the xgrass code is stored in a tarball (outside
> the CVS!). No separate repsitory needed. The Motif code is Open Source
> now, but i doubt that anyone from the Open Source communitiy is willing
> to work with xgrass, as Motif programming is horrible complicated
> compared to other, newer window programming enviroments.
> cu
> Andreas
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
I am a new suscriber to GRASS that we plan to use.  For GUI, we use
wxWindows which work with GTK, Motif, Windows95/98/NT and MAC (with some
delay).  This is a high level API using C++.  It is interesting to consider
