[GRASS5] Re: Windows grass binaries / GRASS branching
Justin Hickey jhickey at impact1.hpcc.nectec.or.th
Mon May 29 05:01:13 EDT 2000
Hello Markus
On Fri, 26 May 2000, Markus Neteler wrote:
> The only problem is the
> src/CMD/lists/GRASS which is parsed for compilation. Either
> we have to hold two lists (stable/unstable) or the compile
> mechanism needs to be modified to
>  1. ignore non-existing modules (as they might not have been checked
>     out if the stable version was acquired)
>  2. ignore compile errors and proceed, maybe collecting the
>     names of uncompiled modules in a log file.
> Especially 2. would be of general interest, I think.
> If 1. is there, we could modularize the GRASS in a first approach
> into smaller, topic-oriented packages.
> In fact the best solution would be that the compile script collects
> the *existing modules* first, then we would get rid of the
> src/CMD/lists/GRASS.
I am not confident in shell programming, but I can easily write a perl
script that can detrmine all exisiting modules if there is a way to
determine if a directory is a module. Maybe the existance of an empty file
called "moduleDir" or something. I don't know if this will be useful or
not but I will volunteer to do it if someone can help with the
specifications for integrating this into the pre-install scripts
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
