[GRASS5] Poll to remove XGRASS from source
Bernhard Reiter bernhard at intevation.de
Mon May 29 03:53:19 EDT 2000
on sun, may 28, 2000 at 02:17:25pm +0200, andreas lange wrote:
> it will be sufficent if the xgrass code is stored in a tarball (outside
> the cvs!). no separate repsitory needed.
i agree, but it will stay in the repository anyway. at least in the old
branches (and then in the attic directories as john will certainly explain
us.  ;-) )
as a general rule cvs keeps the possibility to retrieve any version of
the files it is keeping.
> the motif code is open source now,
mofif if _not_ open source.
read the first two paragraphs of http://lwn.net/2000/0518/
or: http://www.opengroup.org/openmotif/faq.html
clearly stating:
| does the open group public license for motif meet the open
| source Guidelines?
| ANSWER:
|     No. The Open Group Public License for Motif grants rights
| only to use the software on or with operating systems that are
| themselves Open Source programs. In restricting the
| applicability of the license to Open Source platforms this does
| not meet term 8 of the Open Software Definition
| (http://www.opensource.org/osd.html).
> but i doubt that anyone from the Open Source communitiy is willing
> to work with xgrass, as Motif programming is horrible complicated
> compared to other, newer window programming enviroments.
I am not sure if motif is more complicated as, let's say MFC >8-)
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000529/587eeea1/attachment.bin
