[GRASS5] Re: ODBC ready
Markus Neteler
neteler at geog.uni-hannover.de
Thu May 25 04:43:41 EDT 2000
Hi Radim, hi all,
yesterday I could run the new ODBC driver successfully!
Many thank for your big job, Radim!
Notes for others, how I did (I am ODBC newbie..):
Tested on SuSe Linux6.4, PostgreSQL 6.5, unixODBC 1.8.8.
Start: Getting unixODBC: www.unixodbc.org
Compile:
configure
or: configure --enable-gui # strange: on one machine I got the
# ODBCConfig, on another it wasn't generated
make
make install
-> Files will go to /usr/local/lib/
Instructions to set up ODBC:
file:/home/user/unixODBC-1.8.8/doc/AdministratorManual/odbcinst.html
Get it running with GRASS:
a) establish ODBC connection to PostgreSQL (Oracle, ...):
Use
ODBCConfig
add new system DSN: means: add a new System DSN for each
database within the PostgreSQL. Only admin can add System DSN.
To add user specific DSN, use "User DSN".
Check for a list of databases:
psql -l
Example:
Assume, we have an existing database "boden" with table "humus":
Description:Bodendatabase
Host: localhost
Username: neteler
Database: boden
Use
DataManager
to watch the settings.
b) Start GRASS:
List of drivers:
db.drivers -f
You should see the odbc driver (otherwise edit /etc/dbmscap).
List of available databases:
db.databases -l
(Note: To easily import a DBase database into PostgreSQL, use
pg.in.dbf from Alex)
Look for databases selectable through ODBC:
db.databases -l
You can preset most parameters:
db.connect driver=odbc database=boden user=neteler
db.connect -p
Look for tables:
db.tables driver=odbc database=boden
Describe a selected table:
db.describe driver=odbc database=boden table=humus
db.describe driver=odbc database=boden table=boshp
Describe the existing columns in table:
db.columns driver=odbc database=boden table=humus
db.columns driver=odbc database=boden table=boshp
Select statement (db.select can read from stdin):
db.select driver=odbc database=boden
select * from humus where humus > 1
CTRL-D twice!
- outout is zero at all.
-> Radim: what about table selection? Don't we need to select
the table as well? I'll check the TODO list...
Or did I misuse it?
Disconnect:
Congratulations, Radim!
Best wishes
Markus Neteler
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
