[GRASS5] XDRIVER popup bug
Carl Anderson
candrsn at mindspring.com
Tue May 23 00:22:48 EDT 2000
Markus,
Here is a quick fix for the indicated problem
I changed src/display/devices/XDRIVER/XDRIVER24/Panel.c
so that if any part of the window was off screen during
an image capture (popup, menu) the window is moved such that
the entire window is on screen.
try it using d.zoom
put part of the window off screen to each side (top, bottom,..)
I don't like this as a long term solution.
I would prefer popups to be real popups.
To see what my changes are diff Panel.c with the new Panel.c
Unfortunately the sleep(1) was necessary to give XDRIVER24 time to do
its stuff. I hope that moving from file/fifo's to sockets help that,
so that nasty line can be dropped.
C.
E-Mail: candrsn at mindspring.com
Flying Monkeys Usually Mean Trouble.
#include <stdio.h>
#include "includes.h"
extern int SCREEN_TOP;
extern int SCREEN_BOTTOM;
extern int SCREEN_LEFT;
extern int SCREEN_RIGHT;
extern Display *dpy;
extern Window grwin;
extern GC gc;
extern Pixmap bkupmap;
extern int backing_store;
/* Saves all bit plane information for the screen area described by
* top, bottom, left, and right borders. Associates the saved
* information with the string "name". This name is a local system
* file name which is actually be used to store the image. */
int Panel_save (char *name, int top, int bottom, int left, int right)
int fd;
int width, height, i;
XImage *impanel;
char *dpoint;
XWindowAttributes xwa;
Window mywin;
int win_px, win_py;
int win_qx, win_qy;
Window trashwin;
int new_x, new_y;
if ( !XGetWindowAttributes(dpy,grwin, &xwa) )
return (-1);
XTranslateCoordinates(dpy, grwin, xwa.root, -xwa.border_width,
-xwa.border_width, &win_px, &win_py, &trashwin);
win_qx = (DisplayWidth(dpy,DefaultScreen(dpy)) - win_px -
xwa.border_width * 2 - xwa.width );
win_qy = (DisplayHeight(dpy,DefaultScreen(dpy)) - win_py -
xwa.border_width * 2 - xwa.height );
if ( win_px < 0 | win_py < 0 | win_qx < 0 | win_qy < 0 )
new_x = win_px;
new_y = win_py;
if ( win_px < 0 )
new_x = 10;
if ( win_py < 0 )
new_y = 10;
if ( win_qx < 0 )
new_x = DisplayWidth(dpy,DefaultScreen(dpy)) - xwa.width - 10;
if ( win_qy < 0 )
new_y = DisplayHeight(dpy,DefaultScreen(dpy)) - xwa.height - 10;
fprintf (stderr, "Interactive Windows must be fully visible\n");
fprintf (stderr, "moving window \n");
XMoveWindow(dpy, grwin, new_x, new_y);
return (-1);
XFlush (dpy);
sleep(1);
SCREEN_TOP = xwa.x+1;
SCREEN_LEFT = xwa.y+1;
SCREEN_RIGHT = xwa.width - 1 ;
SCREEN_BOTTOM = xwa.height - 1;
/* Adjust panel edges if outside window necessary */
if (top < SCREEN_TOP)
top = SCREEN_TOP;
if (bottom > SCREEN_BOTTOM)
bottom = SCREEN_BOTTOM;
if (left < SCREEN_LEFT)
left = SCREEN_LEFT;
if (right > SCREEN_RIGHT)
right = SCREEN_RIGHT;
height = bottom - top + 1;
width = right - left + 1;
/* Get the image off the window */
if (!backing_store)
impanel = XGetImage(dpy, bkupmap, left, top, width, height,
AllPlanes, ZPixmap);
else
impanel = XGetImage(dpy, grwin, left, top, width, height,
/* open the file */
fd = creat(name, 0644);
/* write the lower coordinates and size of image */
write(fd, (char *) &left, sizeof(left));
write(fd, (char *) &top, sizeof(top));
write(fd, (char *) &width, sizeof(width));
write(fd, (char *) &height, sizeof(height));
write(fd, (char *) &(impanel->bytes_per_line),
sizeof(impanel->bytes_per_line));
write(fd, (char *) &(impanel->xoffset),
sizeof(impanel->xoffset));
write(fd, (char *) &(impanel->depth),
sizeof(impanel->depth));
/* write the rasters, one line atta time */
dpoint = impanel->data;
for (i = 0; i < height; i++) {
write(fd, dpoint, width);
write(fd, dpoint, impanel->bytes_per_line);
dpoint += impanel->bytes_per_line;
/* another way of writing data
write(fd, impanel->data, impanel->bytes_per_line*height);
close(fd);
XDestroyImage(impanel);
return 0;
/* The saved panel associated with "name" is restored. */
int Panel_restore (char *name)
int fd, i;
int top, left, width, height, bytes_per_line, xoffset, depth;
char *data, *tdata, *malloc();
XImage *newimage;
/* open file, read the dimensions and location */
if ((fd = open(name, 0)) == 0) {
fprintf(stderr, "Cannot open panel %s\n", name);
return (-1);
read(fd, (char *) &left, sizeof(left));
read(fd, (char *) &top, sizeof(top));
read(fd, (char *) &width, sizeof(width));
read(fd, (char *) &height, sizeof(height));
read(fd, (char *) &bytes_per_line, sizeof(bytes_per_line));
read(fd, (char *) &xoffset, sizeof(xoffset));
read(fd, (char *) &depth, sizeof(depth));
/* allocate space and read the data points */
data = malloc((unsigned) width * height);
data = malloc((unsigned) bytes_per_line * height);
/* another way of reading data
read(fd, (char *) &data, bytes_per_line * height);
tdata = data;
read(fd, tdata, width);
read(fd, tdata, bytes_per_line);
tdata += bytes_per_line;
close(fd);
/* now that data is in memory, get the window's attributes and turn
* it into an image, then draw it. */
if (XGetWindowAttributes(dpy, grwin, &xwa) == 0)
return (-1);
newimage = XCreateImage(dpy, xwa.visual, 8, ZPixmap, 0,
data, width, height, 8, width);
newimage = XCreateImage(dpy, xwa.visual, depth, ZPixmap, xoffset,
data, width, height, 8, bytes_per_line);
XPutImage(dpy, grwin, gc, newimage, 0, 0, left, top, width, height);
if (!backing_store)
XPutImage(dpy, bkupmap, gc, newimage, 0, 0, left, top,
width, height);
XDestroyImage(newimage);
return 1;
/* The saved panel associated with "name" is deleted. */
int Panel_delete (char *name)
unlink(name);
return 0;
