[GRASS5] Digitizer drivers in v.digit
John Huddleston
jhudd at itc.nrcs.usda.gov
Thu May 11 11:18:59 EDT 2000
Markus (et al)
Manually moving directories and files on the CVS server from the
repository to outside the repository is not usually recommended.
Let the CVS users execute the command
'cvs remove file-to-be-removed'
then the file-to-be-removed stays in the CVS repository
but is not longer accessible to main (HEAD) branch
developers. However, it is still available for those
who have tagged whole sections of code that need
that file. On the CVS server, an Attic directory is
created and the file goes there. Thus the file is
still available for older builds (compliance with older
systems or standards, etc.) but no longer is "seen"
by developers working at the HEAD. The l option
on cvs remove command is local directory only. The
R or recursive option is default if no argument is given.
John Huddleston
----- Original Message -----
From: Markus Neteler <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Thursday, May 11, 2000 8:51 AM
Subject: Re: [GRASS5] Digitizer drivers in v.digit
[snip]
> > There were "unused" files in the v.digit directory as well, and we
wanted to
> > delete these (after all, I like to clean up code when I can :). Markus
has
> > moved them to an unused directory in CVS and I recompiled v.digit
without them
> > and all went well (Markus, the new directory "unused" did not show up
when I
> > did the cvs update, is this a problem?). So in summary, we are confused
about
> Mhh, it should. I would like to pass the question on our CVS
> specialists :-)
> Kind regards
> Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 3059
max: 0
