[GRASS5] Re: Layered driver
Markus Neteler
neteler at geog.uni-hannover.de
Wed May 10 11:34:04 EDT 2000
Hi Pierre,
[cc to the developers list]
>If work on the driver seems to be of interest, maybe a "CVS branch" could be
>created untill stanility is reached, to allow efficient team wotk? Maybe you
>could explore this issue with Bernhard at Intervation.de ?
You will have read the discussion in grass5-list. I suggest
you start a new branch for the XDRIVER2 changes and display
module modifications.
Note: You have commented src/general/gis in src/CMD/lists/GRASS in
the patch you sent to me some days ago. This is a problem as the
GRASS etc/GIS.sh won't be created then. Just uncomment the XDRIVER2
line and d.layers line in src/CMD/lists/GRASS which I have already
added (commented currently).
Then we can all learn about branches and related stuff from your
example!
Thanks in advance
Markus
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1595
max: 0
