[GRASS5] [moored@reed.edu: Re: Bugreport GRASS 5]
Andreas Lange
Andreas.Lange at Rhein-Main.de
Sun May 7 19:45:38 EDT 2000
Markus Neteler wrote:
> OBJ.i586-linux-elf/main_ogl.o: In function `main':
> /home/grass/src/grass/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/main_
> ogl.c:188: the `gets' function is dangerous and should not be used.
> OBJ.i586-linux-elf/new_init_graphics.o: In function `init_graphics':
> /home/grass/src/grass/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/new_i
> nit_graphics.c:570: undefined reference to `GLwCreateMDrawingArea'
> nit_graphics.c:629: undefined reference to `GLwCreateMDrawingArea'
> collect2: ld returned 1 exit status
> make[4]: *** [/home/grass/grass5.0/etc/bin/contrib/cmd/r3.showdspf] Error
The function GLwCreateMDrawingArea is from libGLw and needs Motif as far
as i could figure out yesterday. The Motif parts from the widgets-mesa
directory are not very well tested until now. I think that Motif is
needed to compile libGLw, i have lesstif (0.86.5, very old version)
installed and could not compile r3.showdspf, produced the same error as
above.
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 2572
max: 0
