[GRASS5] Splitting GRASS 5 into stable and unstable
Markus Neteler
neteler at geog.uni-hannover.de
Thu May 4 15:00:51 EDT 2000
Dear Developers,
as GRASS 5 becomes partly stable, it will be a good idea
to release a stable and a developers version.
As discussed with Bernhard, a GRASS 5 numbering scheme
analogous to the Linux numbering scheme would be useful:
Odd number for development versions, even for stable versions:
5.1.0 is the first development tree release
5.0.0 is the first stable release
The stable release should contain *only* working modules.
So the number of modules would be reduced comparing to
the development tree.
Another reason for the version splitting is the forthcoming
substancial changes in source code structure:
- GRASS must be split into packages (GRASS-Core, GRASS-Hydrology,
GRASS-...)
- auto-conf shall be included for every module (new Makefile
mechanism) [Eric may take care for this]
- a new display system shall be included [Pierre and Carl already
work on this topic]
Due to these heavy changes GRASS 5.1.0 (devel) might become less
stable as GRASS 5 beta8 (or 5.0.0) for some time. But this code
structure update is necessary.
Your comments are welcome!
Markus Neteler
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1676
max: 0
